I took apart the carburator to clean out and I can't remember exactly where the springs that are inside the float are supposed to go I've tried to look up schematics but I think I am missing a spring maybe need helpt:confused::confused::confused::confused::aargh:
    • By Elk
      2002 Polaris Magnum 325
    • By mikeexplorer
    • By jordan_ATV
    • By Travis_Smith
