That roughness ? The piston nearly seized.
By the looks of it it was caused by overheating.
See just in front of your thumb, on the corner of the skirt, there's a dark spot.. Well that looks like the sort of hard surface pistons get when they overheat. The black bit will be hard and hard to scrape off if it's that.. otherwise it's just an oil spot.. haha. Try scratching the black bit with a scraper or screwdriver. It's some sort of aluminium anodising or something that happens and it's like that surface they put on aluminium doors and windows. Sometimes there can just be a tiny amount and it seems like the piston could be re-used, and they can, but they have a sharp tap when they would normally have piston slap noise, and they can tap/rattle a lot in use.. just because that little spot is too harder metal.
I've seen worse. One thing that's a bit strange is that despite the skirt getting hot, the heat doesn't appear to have come from the top of the piston. The rings haven't seized/been jammed in the grooves. Just the skirt got hot. Water cooled engines that have the lower part of their cylinder cooling passages full of crud(used to be common), do that. Unusual these days to have a water jacket full of rusty deposit..
    • By mga
      I just saw a video on TikTok where some guy took the rear end off an ATV and bolted on a roto tiller in place of rear wheels. I wish i saved that video to post here....good thing it was 4 wheel drive...lol but, it seemed to work.
      I'm not sure how he made it bolt on to the drive....
    • By davefrombc
      This video  of BMW  engines being  manufactured in China very well  illustrates where  all  the  unskilled repetitive  jobs  have gone, and  why  they're not coming  back in America  or anywhere  else.  What  BMW  has  done   in  China  is  being repeated  by every  industry  everywhere. If it  can be  automated, it will  be and except  for  a  handful of  operators the only  people  employed  by those businesses  will  be  tradesmen maintaining  the robots.
      Education  and trades training is  far  more important today  than it  has  ever  been.
    • By oxidized_black
      Yahoo! News Canada - Latest News & Headlines
    • By kfwa
      Hello
      I have an '86 LT230s.
      recently I put a new top end in. Took it out for a test drive after the rebuild and the screw holding the cam chain tensioner was loose and fell out. When I stopped the motor I couldn't start again. Fearing the cam chain jumped the timing I pushed it back, reset the timing by using a screwdriver in the spark plug hole to determine the top end.
      Bike still wouldn't start where in the past it would start on the first kick. I was pretty confident I hadn't screwed up the timing so I pulled the spark plug to spray some starting fluid in the chamber and noticed the spark plug wasn't getting any spark.
      I tested the ground, the usual suspects. I had a donor bike so I replaced the coil and the CDI. Still nospark.
      So here is where is gets interesting.
      I take the stator cover off, wipe down the flywheel and coils and I guess what you'd call the magneto because they all had a light layer of oil on them. In order to take the stator cover off of course I had to drain the oil. So after wiping it down, putting the stator cover back on I get a strong spark.
      In my haste, I start the motor and let it run for about 20 seconds before I realize I didn't put the oil back in.
      I put the oil back in...and you guessed it - now I'm back to having no spark.
      I'm trying to figure out if I need to replace something - clearly I can't run it without oil.
      any ideas would be welcome.
    • By mywifeknowseverythin
      Interesting statistic
      "A 2006 study found that the average American walks about 900 miles a year.
      Another study found that Americans drink an average of 22 gallons of beer a year.
      That means, on average, Americans get about 41 miles per gallon."
      Not bad!
