2006 Artic cat 400 4x4 automatic transmission no spark
2006 Artic cat 400 4x4 automatic transmission, no spark. Coil ignition assembly, spark plug (wire, boot) checked and replaced. Still nothing, ideas?
Edited by Devmo13
topic title
Test kill switch.  Buy service manual and multi meter and start checking electrical components. Make sure your grounded if not you may have burnt up your new coil-ignition. I've never seen a plug not show some kinda life unless it's totally f-up. Make sure your boot is actually on right.  Im sure you know the battery has to have a lot of life in her. Keep us posted.
    • By Johnnynv
      I recently bought a 2006 KFX  700 that had been sitting for 10+ years, started to replace the fuel system and the fuel pump has a connector that does not fit the same as original.  The plug has opposite slot as original.  There are two plugs on fuel pump bracket, some tiny sensor and fuel pump.  The new fuel pump plugs in the same place as tiny sensor, where as the old fuel pump plugged into opposite position.  I took old connector off bad fuel pump and repined it to new one, but now am questioning if this was the right thing to do.  I did pay attention to wire placement but just feel like there should be a direct replacement.  From the pictures on partzilla website, I cannot find a different option.  Has anyone run into this issue?
    • By TomJulio
    • By Arizona
    • Guest
      By Guest
    • By jordan_ATV
