2000 Arctic Cat 500 Need Carb
By tepin
By tflack500tbx
Background,
Any Ideas?
By kevinohio
By Gtc4d
I recently purchased a raptor 80 for my grandson for christmas. I am trying to make sure it is running properly. i have rebuilt the carb and adjusted the carb idle then the mixture to middle of where it runs rough and it runs great for about a min or 2. then it stalls out. I can usually choke it and it will start so i feel it is lacking fuel. the fuel shutoff valve has been changed and i checked it for good fuel flow. any ideas of what to check next. I am planning to vfy fuel float height tomorrow. I visually checked it by turning carb upside down when i had it apart and it looked level. any ideas are appreciated.
Thanks.
Todd
By digrig
Hey everyone,
