2000 Polaris Xplorer 250 oil pump questions
By rjsummer
By en4cer
Problem number 1,
2000 Polaris Xplorer 400. No start, has spark. Has fuel ,found Low Compression less than 60 psi. What to do next?? Going crazy here.
Problem number 2.
1994 polaris Sportsman 400 starter won't engage. Button on left side with light switch seems to be almost stuck in, weak spring behind button?
Any help would be nice.
Thanks Chris in West Central Minnesota
By davefrombc
1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
By en4cer
I have a 2000 Polaris 400 xpress with a no start situation, I have spark and fuel. Wont start on starting fluid.
New fuel filter and spark plug. Did run prior on full choke. Then died and not start since. I feel dumb , any body have a clue???
By middlebrookgt
