Join Today, It's Simple and FREE!
By HeWasRidinDirty
Hello all. I got this yzf for almost nothing. It's in pretty good shape. However, it's pretty stubborn on cold start-up. I noticed while cranking it over that there was water dripping from what appeared to be the exhaust where the pipe bolts on. It did fire up and I could smell coolant in the exhaust. The P.O has installed a toggle switch for the cooling fan. I'm thinking that maybe it overheated and cracked the head or something? Any tips/ advice is much appreciated.
By Frank Angerano
Take a look at this. I just ordered it. Wondering what your thoughts are ? I mainly like to get my bikes up In the air so I’m not killing my back any more. I either build up some stuff I have laying around etc but this looks like it’s going to work out well.
Goplus 300lb Motorcycle Lift Table Hydraulic Cycle Dirt Bike ATV Scissor Jack Lift Hoist Center Stand Lift https://www.amazon.com/dp/B01BRBKA82/ref=cm_sw_r_cp_api_i_Kx5wCbPR1HRPA
By Hilltopmike
Hi Folks,
Just bought this 1991 King Quad and it is missing the right front axle. It runs and drives in 2 wd, would be nice to find parts or whole axle to make the 4 wd drive work again. A rebuildable axle would be fine. Any help would be great.
Thanks Hilltopmike
By anryu451
Rescued this thing from sitting in a warehouse the last two decades. Finally got it to fire, but when I put it into neutral to do so its now stuck in neutral, and wont shift no matter how much pushing, rocking, etc. Even with throttle it wont. Range lever on left side will go from H to L, but not to R, and this makes no difference on it being stuck in neutral.
Any suggestions?
By Frank Angerano
So here’s a question. I have seen a few members that have recently purchased a used bike. Also a HUGE amount of so called new members who have purchased a used bike and have come here “just here for a manual”.
Some have been disappointed with the bikes and or knew they were getting a broken bike with some mechanical experience thinking hey I can fix it. So here’s my take on buying a used bike. Anyone who has followed some of mine and other members posts about what to look for when buying a used bike here’s a few pointers on what to look for.
1. I always check the oil and look for moisture, metal shavings and color.
2. Feel the compression or take a compression tester with you.
3. Check for spark (if the bikes not running)
4. Take a small jumper pack to verify that the starter cycle works and the bike cranks.
5. Look for bent or cracked frame/welding that was done on the frame from maybe a wreck.
5. Mismatch plastics by looking under neath.
7. Bolts on the engine/frame that look like they are stripped from someone taking the bike apart.
8. Any kind of scilicone or gasket adhesive that was used on a cover plate or engine seem where the engine was taken apart.
9. Patches on the exhaust pipes with sheet metal or jb weld patch material.
10. Wiring messes on the harness like bundles of tape where the harness was opened up and taped up for an after market device or just plain butchered up.
11. Put the bike in gear (running or not) and roll the bike back and forth to see that the gears work and you feel resistance like the engine is trying to spin while pushing it forward as if you were push starting it
12. I keep a vin# decoder website on my phone as a favorite to double check the year of the bike .
All though nothing is fool proof these tips will help you along while buying a used bike. Not only that but it will help you negotiate a fair price for a bike that may have one of the above problems.
I have minimized this entire process down to about 15 mins. I buy all the time so I don’t expect you to do the same or have a compression tester etc but use some of these tips when buying and go into the purchase with confidence!
I would like to hear anyone else that has any input on buying a bike and what to look for!
Similar Tagged Content
By wanrep
View File 2000 Yamaha Big Bear YFM400FWNM Service Manual
Factory service manual for the 2000, 2001 Big Bear 400.
Submitter wanrep Submitted 01/18/2019 Category Yamaha ATV
By Barry Wilford
got a 350 big bear 4x4 about a 1988 not sure. need upper ball joint, but wales atv say only available with suspension arm . any thoughts appreciated.
By frank marano
I have a 01 350 Big Bear with less than 200 miles on it, also has warn winch and Boss plow, anyone no what it's worth? Thanks
Yamaha YFM 350 S 04 - Service Manual Supl.pdf
By qcm413
Hi,
Thanks for a newbie on this site !
i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
thank
