By cruteg8
I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
By Matthew Alloway
What is the best paint for a swing arm. I know powdercoat would be the best, but I am looking for paint type that I can easily do at home.
By 97kingquad
By sunn
Have a high heat issue on the right side panel on my 2021 cforce 400, as complained about by the wife.
My heat gun shows after 15 minute ride in ambient 91 deg temps; 690 degrees on front end of muffler close to entry pipe and 375 on exit side of muffler. The right side plastic (where wife's leg would touch) was showing 175 degrees. This is rediculous!.
As I understand the muffler has a built in catalytic converter which obviously kicks off high heat particularly at front end of muffler, but the heat is atrocious.
What is everyone doing about this problem? Is there a replacement muffler to eliminate this issue?
By TravisCr
I don't know if I shouldn't have posted but I this is my second post on this (other was in regionals Forum) The family has a 2-up 2004 Artic Cat and a 2003 Polaris Sportman and we are looking for fun/easy rides in the Colville, WA area- 70 Miles North of Spokane WA, we have a small trailer we can haul these with but need to find some good areas for beginner.
Thanks in advance for any suggestions.
