STOLEN ATV: Grandkids Christmas Present 2016
By shorty
I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
By Ajmboy
I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
By kiriyaaoi
By Notallthere
Hi everyone This little monster came to me as a non runner and to sort it for a friend. Had it in bits thrown the service bits at it but nothing, it struggles to turn over unless you put your hand over the intake then it spins like a demon. The valves are adjusted correctly and I am just lost where to go next.
