2012 TRX400X cranking/idle problems-Help Newbie Plea
By Bobbywolf
Thanks for any assistance.
By p5200
By p5200
I'm having trouble identifying Mark. I know where the mark is in the Stator cover. Is the T at about, the 12 o'clock position in this photo? I've got to buy another Stator cover as the one I have has a hole at the bottom of it. Due to failing eyes, I have a lot of trouble anymore. Thanks! 🙂
By Uglyside38
By Werewolf
