So we have a 2000 BearTracker 250cc. We got hit by a tornado and it got flooded out. Water was well over the handle bars and it actually moved almost 40 yards by the water. Anyway, I've pulled the carb and drained the tank. New fuel and a "clean" carb. It fires right up first crank like it used to but bogs down after you try and give it any gas. Think it could still be a carb issue? Carb had a fresh rebuild in April and might have 10-12 hours on it since. After we got it out, It was never started until I took the carb off and cleaned it along with draining the tank. Carb has now been off twice with no differences. Any other ideas?
also the water seems to never end in the exhaust. I've gotten out as much as I could but it's still steaming quite a bit like there's more in there. Could this be the problem? I've never had an ATV get flooded out like this one before. Any help or other ideas would be great. Thanks yal.
Did you also change the  oil and filter?.. Water  vapor  could be coming  from  water  in the oil  boiling  off and  entering  the  intake through the  breather tube for the  crankcase.  Try adjusting the  idle  air  screw and or  the  needle valve settings. Bogging  on  acceleration sounds like  it  isn't  getting enough  fuel  (running  lean) when  you open the  throttle.
    • By mga
      on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament  I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
      I'll post a pic later.
    • By Need-help-with-quads
      Can anyone help me?
    • By anthonyd256
      I have a 99 Yamaha bear tracker and I have converted the front brakes from drum to disc fairly easy but I cant figure out how to convert the rear with out hacking apart the rear arm. tried to use parts from a wolverine since the rear arms look similar but the caliper mount didn't line up on the bear tracker axle. Can anyone give me any clues or has anyone successfully converted the bear tracker rear brakes. I would even purchase a conversion kit if there is one. Any help on this would be greatly appreciated.
      Anybody got a service manual for a 1989 Yamaha moto 4 250?
    • By Lukequinn
      I have a Yamaha beartracker 250 that I can’t seem to get running right
      i am after replacing the spark plug, carburettor, and the carb boot to the engine when she starts she revs up like mad  even when the mixture screw on the carb is fully in when running she pops and stalls and won’t rev up
      has anybody have any idea what could be wrong with it thanks
