on my left brake handle (for the rear brakes) there's two wires attached to it. What are these wires for? They can't be for the tail light, since it only has on filament I tried to trace them, but i got lost in the harness. I checked wiring schematics, but didn't see anything like that.
I'll post a pic later.
So I have an 89 Yamaha moto 4 250cc and when I ride it, itll get hot after like 10-15 mins and then will just die and turn off.
It's has new carb rebuild, new air filter, new battery, new spark plug so I don't think it's a crack in the spark plug
Can anyone help me?
I have a Yamaha beartracker 250 that I can’t seem to get running right
i am after replacing the spark plug, carburettor, and the carb boot to the engine when she starts she revs up like mad even when the mixture screw on the carb is fully in when running she pops and stalls and won’t rev up
has anybody have any idea what could be wrong with it thanks
