For 2018, Arctic Cat has it's line up includes the ALTERRA branded ATV which is kind of short for "All-Terrain" and makes good use of the shortened word with some of the features these ATVs are now coming with. Whether you are using it to hunt, ride in mud, ride on the trails, use it for work, or just play around, Arctic Cat has an ALTERRA ATV for you.
The ALTERRA comes in 90, 150, 300, 500, and 700 models with 2 versions in the 700 series with the ALTERRA TBX 700 leading the group of ALTERRA ATVS with:
  • 695cc Single-Cylinder Closed-Loop EFI Engine
  • 300-lb Capacity Rear Cargo Box
  • Electronic Power Steering
  • 10-Inch Suspension Travel
  • 11-Inch Ground Clearance
You should also check out the ALTERRA MUDPRO 700 LTD Built with a 695cc EFI engine, ruthless suspension and a competitive streak, engineered for riders who like to get dirty and won’t settle for second place!
Check out the models below:
Alterra MudPro 700 LTD
SINGLE-RIDER
$9,999USD
Alterra VLX 700
SINGLE-RIDER
ALTERRA VLX 700
$5,999USD
Alterra VLX 700 EPS
SINGLE-RIDER
ALTERRA VLX 700 EPS
$6,999USD
Alterra TBX 700
SINGLE-RIDER
ALTERRA TBX 700
$9,799USD
Alterra 500
SINGLE-RIDER
ALTERRA 500
$4,999USD
Alterra 300
SINGLE-RIDER
ALTERRA 300
$3,999USD
Alterra 150
SINGLE-RIDER
ALTERRA 150
$3,499USD
Alterra DVX 90
SINGLE-RIDER
ALTERRA DVX 90
$2,999USD
Alterra 90
SINGLE-RIDER
ALTERRA 90
$2,999USD
Full line up of 2018 Arctic Cat ATVs can be seen at Textron OffRoad: https://www.textronoffroad.com/atv
  • 5 months later...
    • By tepin
    • By Shorty51
    • By jeffinotown
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By DarkRider
      Hey Everybody,
      Durability is how long I can go without something breaking. OR how often things break with seeming not much of a good reason. Reliability is about the on-trail experience of having everything work properly as designed (i.e. Starting up and being able to get going without much issue, the 4wd drive engages without quirks, I can park it on a hill when needing to help someone else without worrying it'll roll away, etc) My Brute Force 750 is a perfect example of why Durability and Reliability were rated so differently. With durability, I really never felt like I've had anything break on the thing that was really from riding it. Which is great in that regard. But all of the things i've had to fix on it seem more so in it's design. The infamous KEBC code on the dash that refused to go away even after completely cleaning and lubing the KEBC and confirming it functions properly. Hard starting issues. 4WD requires you to roll about 10 to 15 feet to engage, so if you get stuck in 2WD, you're in a pickle. The infamous bus connector that goes bad and stops your charging system from working. I've worked through all of these, but these are all things I'd consider reliability issues that happen really at no fault of mine as I ride it pretty gently. Writing up this list has actually put a lot into perspective for me. The King Quad 300 really is a superb quad. The inclusion of the Super Low range provides stellar engine braking down pretty much any hill you can think of, it seems like it's unmatched. It has great gas mileage, and it's been dead reliable despite being a 1994. It's got 4x4 AND Diff lock, and the semi automatic transmission also help with not letting the quad get out of control down a hill. Plus it's more fun to me and gives me a bit more to do while riding. The biggest annoyance so far has been the parking brake. No matter how much I adjust it, it just doesn't seem stay adjusted after some time. I believe this might just be flawed on these models.  Also, parts availability is not the greatest on these since they don't make anything newer with any similar parts. Front axles are quite expensive, rear drive shafts go for $400 to $500 brand new, etc.
