  • Ajmboy changed the title to Is it safe to lay an atv on its side? ATV Work
I changed your topic title to generate more replies by having what you are actually asking about in the title. 😁
I don't recommend it unless absolutely necessary. If you are working on your ATV, you should raise it up. As far as if it's safe, I would disconnect the battery so you don't get any ignition starts accidentally and the other safety issue is rolling over on someone, so make sure it's well supported.
It is really  no more safe nor  unsafe to lay a quad  over than  it  is  any  other  4  wheeled  vehicle .. The  question is  why?
If  the  battery  is removed,   and  fluids   such as  the coolant in liquid cooled machines oils in the  motor  and drive train  are removed there  shouldn't  be a  spillage problem .
About the  only reason  I  can see to  lay one over  would be  to  weld up  cracks  in the frame that  laying one  over  would  make for easier access.  If it  is  just for storage,  I'd  say  it  is  not a good idea  at  all.
Laid  over  properly to  protect the  plastics  and  other exterior  parts won't  hurt  anything though.
When I replaced my stator and pickup last year on my big bear 400 the pickup coil started making contact with the flywheel. instead of draining all of the oil I put in it after the initial install I leaned it over on a stack of pallets I had. I did brace the upper wheels with blocks so I wouldn't fall on me.
I Wouldn't put it fully on its side because oil can seep past the piston rings if it sits to long that can lead to hydro-lock.  I did however pull the spark plug and crank it when it was back on all 4 tires to ensure that there was no oil trapped in the compression chamber.
  • 4 months later...
The fluids will be the biggest issue. If it's just for a quick activity you'd probably be fine (aka, less than 15min.) but longer would pose all the concerns above and just get worse. I had a rider roll one in the woods and it took us about 45min to get out there and stand it back up. Fortunately with giving it a burst of full-throttle it fired right back up with nothing notable as an issue.
(That said it was an air-cooled Kawasaki so fewer 'things' to drip/settle out that could cause damage...)
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
