OK, Removed starter from right side pretty easily. Starter spinning well, good torque.  Still have to remove left cover to get to gear.
I've looked at starters with gear in place for sale.  Also see one way bearings.  I don't have a diagram of the set up.  Which or both?
Thanks, Cavry
  • 5 weeks later...
  • 3 months later...
  • 7 months later...
On 4/7/2018 at 10:29 AM, Ajmboy said:
Did you figure this out? Is this a Kawasaki Bayou?
yea- same model as mine- klf300b if I'm not mistaken. (bayou 300)
On 7/24/2018 at 4:06 PM, Quad Bug said:
At the risk of sounding dumb, what is a torque limiter?
I'm wondering the same thing?  I know my kawasaki acts like a diesel- no acceleration, but tons of low end power
Finally!  I am back to a limited .degree.  Family member medical condition is under control. I have the bayou running well after 3 days of effort getting everything back together and locating a few missing bolts
The torque limiter is inside the left alternator housing on the end of the starter shaft. I'm not exactly sure of the mechanical function and I haven't cut one apart yet to see.
I'll be in and out of here for a while. I am facing lumbar spinal surgery. 2 vertebrae are deteriorated and are misaligned badly and there is no disc between 4, all bone on bone.  Not sure what the future holds. No complaints, and I'll survive well, it just may take a while.
Good luck with your surgery!
OK, information I found on Utube says the Torque Limiter is like a one-way ratchet to prevent backfires from stripping the splines on the starter shaft.
    • By logray
      Hi all,
    • By HoldenBoy
      Hi all,
    • By toe420
      I got a couple yamaha moto 4 225cc quads. The guy gave me several old starters with them. I see kits are available to rebuild them but does anyone have tips or tricks for doing it? I haven't rebuild a starter before so im not sure what to look out for.
    • By crankin
    • By Arizona
      Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
      Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
      too blury and cant tell wire color. Just too small. Thanks Az
