Thanks, I think its 4Ah difference.  I guess my concern was that with EFI, fuel pumps, headlamps, aux headlamp, taillights, warmers, electronic display... that somehow the bike couldn't supply that load once running ... and required the extra capacity to slowly drawn down...
The lower priced YTX16-BS is 230 CCA, and the YTX20CH-BS is 270.  Although I will use in spring & summer I expect most hrs used will be fall for hunting.  I am then assuming the that CCA in colder weather would be lower than rated and thus the larger unit would give me a safety margin of sorts.
Is my thinking of the drawn down incorrect... and that once running all stock accessories could be managed by the power generations of the bike?
The  alternator   will power all  the  electronics and recharge the battery .  Yes,  cold weather will make the  quad draw more  on starting  cold. The CCA  is the  Cold Cranking Amps rating.  it  is  less than what is available  when  warm.  I searched on the  3  batteries . and found that yes, there is a 4  AH  difference  rather than  2  as I assumed from their  part numbers . You'll  notice  the  OEM  battery   has a  16  in its  part number, but actually an  18  AH rating  while the   cheaper one  with the 16  in its  id  is actually  only  14  AH The  expensive  one   has a 20   , but  only 18  AH  rating ..  Manufacturers  playing  confusing games with their  part  numbers.  The  BS  in the  battery  id  means it is a sealed battery. About the only difference to  me   in the  AH  capacity of the  batteries  is   in how  long  it will  crank  over the engine before  it is  depleted. Once running , the   alternator will run the  quad and recharge the  battery.   No quad  maker  makes one where  the  charging capacity  is  less than the  power  draw.  To  me ,  the  only rating that  makes  much difference is the  CCA. That is the  one that determines whether it will  start the  motor in the  cold
thanks a bunch...
Considering often times I will be alone I'd rather (with appropriate gear as I do when I snowshoe) worry less about the battery state.  The main difference with back country adventuring by snowshoe or by Quad, is that the distance/time I travel on foot to get in is the same distance/time to get out.  But with a Quad a breakdown once you are in is a heck of a walk out.  I'm going to have to spend some time locally learning the bike before I have to rely on it.
On the battery topic, I found this link.  It refers to UPS batteries, but batteries are batteries I guess. and it explains the kC value from the Suzuki manual but I think you are right and those are nuances we probably don't care about as long as the bike starts... but for reading benefit, here it is. LINK
Many UPS  batteries  are designed to   have a  long ,  low  amperage draw down..  They  do  not   usually  have the  high discharge ability  of  starting  batteries and are  unsuitable  for quads or bikes.   Make   sure  if you  go that  route  to  check the  CCA  rating on them if you go that route .  The batteries in the  larger  units  would  likely  be  fine if  their dimensions  fit the  battery  box.
I'd suggest  getting  one of the  new Lithium  ion   jump starters  to   take in your  emergency  kit  on your  quad. They  are  compact,  lightweight  and have the  power  to  boost  a  car. They're a bit  pricey ,  but handy  to  have for   power  peace of  mind if you're out alone .  Many of those  jump starters also  have  a  5 v outlet that  can  be  used to  recharge  a  cell  phone or  any other  accessory  that uses   USB  recharging or operation.
Edited by davefrombc
    • By RadRob
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
