Hi thanks for letting new subscribers to your forum. I have a problem with my 84 Honda 200 trx not starting. I cleaned out the carb and changed the spark plug and still no luck. Any suggestions would be greatly appreciated. Could it be bad gas? Thanks dave
  • Ajmboy changed the title to 1984 Honda 200 trx not starting
Welcome to QUADCRAZY! I changed the title of your topic to 1984 Honda 200 trx not starting and moved it to our Honda ATV forum
Is it cranking and just not catching? If it's been sitting a while it could be bad gas, could be flooded, could have a spark issue. I would spray some starting fluid in the intake and see if it starts, if it does its a fuel delivery issue.
Hey thanks for your help. It has been sitting all winter with a quarter of a tank in it. The inside of the tank is rusting so I am in the process of cleaning it out now. I'm sorry, is the intake where the filter is ? Right in front of the battery if the seat is taken off? Thanks again!! Dave
Yes. i would spray a little starting fluid in there and see if it starts. When you cleaned the carb, did you take it a apart and inspect the float and bowl?
Ok, it's starts with starting fluid so that means there is spark correct? I cleaned the fuel line also. That little adjuster on the side of the carb controls the flow of fuel?  It seemed like it wanted to start a couple of times when I messed with it at first. But nothing now. Not sure where it should be dialed to at this point? Thanks again! Dzve
  • 4 months later...
If you want to remove the rust from your tank you can use Metal Restore or apple cider vinegar. fill the tank completely full and leave it set for several days to dissolve the rust. then flush it out with water then use an air hose to blow out the remaining water then fill it full with fresh fuel. If your not going to use it for a bit pour some motor oil in it and shake it to coat the inside of the tank.
    • By 88bigbear
    • By Cj Winds
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
