Trink9899
2006 Arctic Cat 400 Wont start/run
2006 Arctic Cat 400 w/ 234 miles on it, sat for awhile, had it running in the fall then it just shut off, carb was cleaned, new fuel pump, new gas, new plugs, wont run! any ideas? I'm running out of things to check
Share this post
Link to post
First check spark from coil to plug. Another place, I just had a problem with fuel not flowing from gas tank valve, took it apart and screen was clogging the flow then started right up. Is it turning over? If not try pull start if you have one. It's almost always something simple.
Share this post
Link to post
has plenty of spark,  turns over fine, i blew air back into tank thru fuel line, could hear it in the tank, im going to pull the fuel sending unit out and see if filter is plugged, yes. it's always something simple and stupid, running out of those things to check though!
Share this post
Link to post
Topic moved to Arctic Cat ATV Forum.
Share this post
Link to post
  • Similar Topics
    • By donerightautomotive84
      Ok so 2000 sportsman new.caltric carb new fuel pump new jug and piston new cdi and coil finally get to start it and itll idep for 5 to 10 seconds and die what am i missing people any help id love ya forever lol
      Sent from my LM-Q720 using Tapatalk
    • By Venom
      I am working on a friends 2006 Suzuki LT-Z50 that they purchased not running. I took apart the carb to rebuild it and someone had already been in there... They really destroyed the Air/Fuel Mixture opening in the body of the carb.. It is in no way repairable.
      I have not been able to find an aftermarket carb to fit this model.
      Does anyone know if an aftermarket carb is available?
      Thanks for any help.
    • By Brent Wright
      Can I check the compression just by pulling the pull start even if it doesnt start?
    • By chadh
      I have had this ATV since new, and no work done on the system before. It has an intermittent issue with starting for years but getting worse. Cranks but no start or have to cycle power. No Codes. There are times it starts right up and then times it will not start at all.
      What I have done, new plug, new battery, new coil. Also, the manual I have has spec info for the H1 & H2, but when I check ohms & AC voltage & wire color, it is more in line with the H2 than H1.
      Ok here is what I have done.
      1. new plug then new battery.
      2. checked and replaced the coil- primary was 5ohms and secondary was 20.4K ohms. Since my book said for the H1 the Primary should be less than 1ohm I replaced (new one had the same 5ohms, confused! H2 says 4.8ohms). Book says secondary should be 12k-20k ohms and it was 20K ohms. New coil did not correct the issue.
      3. Stator, AC output while running was good, about 75 volts AC no load between the three yellow wires (but mine are gray wires like the H2). Ohms were also less than 1 ohm.
      4. Crankshaft position Sensor. Again, H1 should have Blue & White but I have Blue & Green like the H2. I have 180 ohms across the Blue & Green wires, so this is good. But when cranking I have 2 volts AC. For the H1 book says 5 volts AC. But H2 says 2 volts AC.
      So, is my position sensor putting out low voltage or do I have the stator assy for an H2 in my H1 ATV from new?  Stator & position sensor are one assy. Has this ever been an issue that was noted? New Stator is $$$ so I don’t want to just shotgun a part.
      Any help would be great!
      Chad
    • By cgilley
      Ran it out of gas last month... Works fine for 3 or so days then refuses to start.... Changed out the sparkplug and it will run for 15 or so seconds before shutting off.... Cleaned out the fuel system and injector and it misses when idling as well as shutting off at idle every so often... It is giving me no other issues and sounds and runs fine while riding... Only issue is cutting off at idle.....
      Ideas anyone??
