2006 Arctic Cat 400 w/ 234 miles on it, sat for awhile, had it running in the fall then it just shut off, carb was cleaned, new fuel pump, new gas, new plugs, wont run! any ideas? I'm running out of things to check
First check spark from coil to plug. Another place, I just had a problem with fuel not flowing from gas tank valve, took it apart and screen was clogging the flow then started right up. Is it turning over? If not try pull start if you have one. It's almost always something simple.
has plenty of spark,  turns over fine, i blew air back into tank thru fuel line, could hear it in the tank, im going to pull the fuel sending unit out and see if filter is plugged, yes. it's always something simple and stupid, running out of those things to check though!
  • Admin changed the title to 2006 Arctic Cat 400 Wont start/run
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By mehim
    • By tepin
    • By Shorty51
