axle bearing Help! 2004 Yamaha Kodiak 400 axle bearing & brakes
By Fonne
Hi
What machine would you recommend ? - Really want a solid machine since I am no mechanic but can perform a early service myself.
By quadnut20
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
By middlebrookgt
By Matdum
Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
thanks a lot !
By jannonballs
2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
IMG_4791.mov
