Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
Is there a common trouble to have the connecting rod bearing failure on a 2006 330 polaris magnum ? I have one who have failed and i want to know if there is something to check specifically
2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
IMG_4791.mov
