My daughters 90cc has been sitting for about 2 years. Went today and replaced carb and added a new battery. Went to crank and no power anywhere. I dont remember if the lights turn on from battery or when its running. Checked all connections and all look good. Pull ig switch out and did light tester and seemed good. Jumped one side of the starter solenoid to the other and it cranks. Also, the 2 smaller wires running to the solenoid light up with tester. Just the starter side does not. Also, if I test the wire from the push start button, its hot with a light tester and when I push the button, the tester almost completely goes dark. Any ideas?
    • By LMI
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
    • By Adamb2025
    • By tds7
