Please, Please , Please
By DarkRider
By Topendcol
Col
By huntindog
TIA
By hardcastle
By beast6228
So the other day I picked up a Lakota 300, it's going to be a new project for a bit, the engine is super clean and so is the frame...luckily the VIN was intact. However, it is the missing the air box (the one that holds the filter) but it does have the air chamber that goes to the carb. These air boxes seem to be pretty pricey, so my question is has anyone had any luck running a pod filter on theirs and if so, what kind of jets are you running? The carb on this one is a Keihin CVK, I have yet to pull it off and inspect it.
