1996 Polaris sportsman 500 test a voltage regulator
By cavry
Thanks for any help
Cavry
By STLJ
Gday all,
Been trying a couple different ways now to download a manual. Not sure what I am doing wrong but could someone walk me thru it?
I go to DL page and click on link
get a pop up for a PDfixer or something
close that and then hit download button and no go
tells me I have reached my limit but I have never DL anything ever.
By N00bie
From Arkansas. Just bought a 2012 Gator 850i RSX because I could not pass up the price. BUT it has an idle problem. So, to be honest, I joined just to get a service manual. I have a choice: 1)Buy a hard copy: ~$100; 2)Buy a CD ~$35.00; Get a direct download for free posting 10 times; or get a download for $29.00 (subscription). Haven't decided what to do yet.
By rgeiser
By Louznmemind
Howdy y'all, I'm trying to fix a neighbors 2015 Brute Force 300. Came in with hard to start and won't idle except on choke issue. I pulled the carb and found the pilot jet as well as the emulsion tube partially clogged. Cleaned up everything, put it back together, still having issues... It will start right up on choke and will also start off choke if you give it just a touch of throttle but it absolutely will not idle unless it's choked just a touch. Also, excuse my ignorance but I'm assuming the "dial" thingy attached to the carb that turns in and out is for setting idle??
