Looking for info on a transmission noise on my cat . Started yesterday when driving sounds like gravel grinding when driving . it fine at idle . checked to see if drive belt was coming apart it is fine . u joints are good as are wheel bearings . Has anyone had this issue before ????
  • Ajmboy changed the title to 2008 Arctic Cat 500TRV Transmission noise
  • 5 months later...
Well found the issue . Bearing on the inner side of final drive carrier was totally obliterated !
Have it tore down to the bottom case . Dealer going to split it for me and then will see how much internal
damage has been done .
  • Sad 1
    • By fixitforfree
      I have a 94 Trail Boss 250 2wd that will not go into forward. Reverse works great but forward just clicks but won’t engage. I’ve verified the shift lever is pushing far enough so I believe I have either an engagement “dog” or mating forward gear that are likely bad. I also see a fair amount of metal on the dipstick magnet. But if I ride the machine in reverse the gearbox seems quiet with no other issues by what I hear. That said I’m in process of pulling the gearbox to see what parts I need. The gearbox has 1341124 as the model number as shown in the photo below but I can’t find any gearbox on eBay or the Polaris parts site that matches that number. Is this 94 model a year that used some special gearbox? My tag on the box even looks different than all the tags on gearboxes I see for sale on eBay. I really want to buy new parts for the ones damaged in my gearbox to fix the one I have but just doing research at this point to see what gearbox I have to know which parts I need. Anyone with experience with this I welcome some advice or direction from what you have learned. Just FYI this machine is new to me but cranks, runs and idles perfect. It’s not beat up and will be a gem when I get this tranny fixed. Thanks.
    • By DexKing
      When you and a group of friends decide you want to take a long group trip of camping/riding/overlanding, how far are you willing to drive for your trip? Right now, i find it really difficult to want to drive more than 2-3 hours one way.
    • By 95kingQuad
      As the title says I am on the search for a used OEM 1995 King Quad Carb. I believe it says Mikuni on the side. If you could even help me find info on which carb it is exactly that would be helpful too, or motorcycles/other quads that use the same carb. Thanks!
    • By roggers
      Hi everyone,
       I often work on both ATVs and larger construction equipment, and I’m always on the hunt for solid OEM manuals—service, repair, and parts. The usual searches give a lot of random PDFs or unofficial scans that aren’t very trustworthy.
      What online sources do you all use when you need a factory manual quickly? Are there sites you’ve found that consistently provide genuine OEM content for ATVs or heavy machinery?
      I recently came across Heavy Equipment Manual, which claims to provide verified OEM service and parts manuals (covering brands like Caterpillar, Komatsu, Kubota, etc.). Has anyone here tried it, or do you have other go-to resources you’d recommend?
      I’m interested in options that are:
      ·        Fast to download
      ·        Cover both heavy equipment and ATV models
      ·        Clear on licensing and safety
      Thanks for sharing your experiences and any recommendations!
