Picked up a non running Rally awhile back. Didn't realize it was a white elephant. Only made for about 4 years. The card was so degraded that the jet towers were crumbling. Turns out that card was only produced for that single engine, which was only produced for those few years. What a nightmare. I have tried several generic carbs and it has been a tuning nightmare. It runs and is a strong little machine that is perfectly sized for teenagers, but man I am turning grey trying to get it running right.  Anyone have any experience with this model?
It’s a 2005. I used generic carbs. First was a flat slide type PWK in 26 or 28mm (can’t recall) but I believe it was too big. Been told those flow a lot more air and I couldn’t even get the jets close to right on that one. Second was a generic PE24. The original was a 24mm. I’ve tried a lot of jet configurations and got this one pretty close but it stumbles in the mid range. I can get the stumble out but then it stumbles on the high end.
Bad news is this carb’s float got stuck the last two nights I worked on it. I corrected though. The needle was sticking in the float tab and causing it to stick. However, I was tuning it last night and noticed the engine was getting a bit noisier (it’s a total and they all seem noisy) than usual and checked the oil. Dang crankcase is full of fuel and oil mixture. Next I’ll drain and refill and cross fingers it’s not damaged before I tune it more.
I’m leaning towards using another PWK but in 21mm. Thinking if the PWK’s flow more than average air so it may equal the original 24 round slide.
Did an oil change. Don’t seem to have any after effects from the fuel in the crankcase. Played with the jets some more and have it the best it’s been so far. 38 pilot and a 135 main IIRC. Now the midrange is stumbling. I’m not giving up! My older son keeps saying “sell it”! I do not like being whipped by something I’m sure I can resolve
If you are filling the crankcase with fuel Id first make sure the petcock is shutting off. I had a similar problem with a Honda 400 that I bought with a fuel problem, you could clean up the carb and ride it for a day and the carb would start filling the crankcase. It had set with ethanol fuel for a couple of years and the petcock itself had began toi dissolve. It sounds like you are chasing the same gremlin
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
      It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
      I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
    • By digrig
      Hey everyone,
    • By T37Mark
    • By Atomusthenes
