2008 Kazuma Jaguar 500 Fuel Pump Hot
By qcm413
Hi,
thank in advance
By USRaider
Hello all!
Kept indoors but hasn't been run in 5 years. We're not trying the engine until the gas is replaced, and the tires are reinflated. But the previous owner said their only issue was stalling when shifting to reverse without giving some throttle.
I'm optimistic! See y'all around!
By robert63
my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
By tater
Hey all, I have a new to me RSX850i that has a lot of exhaust smell in the cab and seems overly loud. I did check the pipes to the can and they seem tight, but you can't see much as they have a heat shield on them. Looking online these machines are loud in the cab to start with, but not too many posts regarding broken pipes and or exhaust smell in cab.
By flyinbrian365
The files it too large to upload so here's a link to my dropbox.
https://www.dropbox.com/s/boeo3kewqeuj7td/2016-20 SXS Pioneer 1000M3-M3P-M3LE-M5P-M5D-M5LE service manual.pdf?dl=0
https://www.dropbox.com/s/z6kjj2to6yyneip/2015 SXS 500M2 Pionneer service manual.pdf?dl=0
Hope this helps someone!!
Create an account
Register a new accountSign in
Sign In Now
