yes as far as I can tell it is. still trying to find something but I can put fuek in intake and will fire up, tested fuel pump it will run. at same time I tried it my display for dash quit also. it lights up yellow but nothing else
yes I unplugged fuel pump ran power directly to pump and it turned on. still testing things and found a relay call ignition/starter relay. It doesn't seem to have any 12 volt power to any of the wires for it
Have you checked all the fuses?
You will probably have to get out the wiring schematic and start tracing the power and see what is causing the problem. One of my customers had the same machine and the voltage regulator / rectifier was bad and cooked the battery it was doing similar issues.
Haha that is funny you posted this. I was just out going through wiring and came to regulator/rectifier plug. It was melted on 2of the 3 wires. I was just about to ask if this may cause dash not to display and fuel pump to not run.
  • Ajmboy changed the title to 2004 Suzuki King Quad 700 Fuel Pump Does Not Turn On
Just saw this topic, I used to have a 2004 KIng Quad. Was going to say that you definitely have an electrical issue if you can bypass and get the fuel pump to work. These quads have more electrical with the fuel injection and all than older quads. Fix those melted wires and try to find out what may have caused it. You may need to replace the regulator/rectifier.
* Topic title adjusted to include ATV issue
hey @AjmboyI seen a post where you were wondering on recalls for 2005 king quads. mine is an 05 made mistake in my post said 04. Did you find out on recalls. Btw I am going to clean up wires and trace them see if there is a bad spot. Thanks for input
  • Admin changed the title to 2005 Suzuki King Quad 700 Fuel Pump Does Not Turn On
I don't remember but saw something somewhere and would search online and on a quick google search I found https://www.cpsc.gov/Recalls/2005/cpsc-american-suzuki-motor-corp-announce-recall-of-2005-king-quad-all-terrain-vehicles
I changed your topic title to include the correct 2005 year 😉
EDIT, here is @Ajmboy's topic
Boy that's an old topic...lol. I don't recall (no pun intended) the recalls on the king quad I had back in the day except for the ecu which I never had done and ended up selling it anyway.
On 10/2/2018 at 7:12 PM, Cory Macleod said:
Hey guys thanks for all the help. A pile of evenings later and it up and running. Was a tiny wire broke off at a junction
Glad you fixed it and thanks for letting us know!
Hey man im having the exact same issue on the same quad! Can you tell me about where the tiny wire was located? (im not much of a mechanic so laymens terms please!)
I can later today. I know it was red wires with green tracer. It was located on the pull cord side behind side cover in the mass of wires that are taped together. I believe one went to fuel pump one to the dash or up front forsure. One to cpu and forget where other went. Maybe to fuses. Hope this helps and if you can’t find them let me know and I can send some pics to you when I get near machine later today
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
