Nice!!!!!!!
Can I be your Brother for a Week in Oregon???????
I do want one.......I want to know if they are Comfortable for long Periods of time....Reliable...Modable(I know they are but Dollar for Dollar which is the Best) you know.....The Consumer Reports Stuff.....The older Carb. Vs. EFI Etc. Etc.
SPILL IT!!!!!!!!
myself..not hating on a rhino here would go with an RZR.
i mean for the type of guy you seem like.. they are faster and mod very well.
the rhino is more of a workhorse IMO.
the RZR has a very low center of balance so flipping isnt that bad of a prob.
i have seen them work well in dunes as well as mud.
but if you want something that you would use for work as much as play i would go rhino.
primarily play. go with the RZR. very fast i have heard..but rhinos dont take that much to go fast..
but the RZR is easier. cause..well its already fast..
just depends on what your doing.
One of my concerns with the RZR is that will only ever be able to seat three with a Different Seat.....I have 5 in my Family and I could buy the Bench Seat and Cage for the Rear.......Ive Seen both in the dunes and they seem to do the Job....the RZR is a Bit Faster Stock though.....
The Rhino responds very well to mods. I have an FMF pipe on mine which all by itself made a huge difference. Trailblazer was correct in some aspects but the RZR is on a quad chassis. Because it is narrow it fits on more trails, but it is very unstable in a high speed turn. They are kinda top heavy. I perfer carb over EFI personally. Black Rhino performance sells a plug and play super chip for the rhino. This alone adds about 10mph and increases throttle response. If you want a wider stance on the rhino you can just flip the rims around. The Rhino has great power at all levels, as long as your tires will grip, you can climb it. There is plenty of storage, unlike the RZR. It comes with a standard 3" receiver. You can take your ball right out of your truck and use it. It can tow up around 1200lbs. Anything else you want to know?
Ha Ha, it happens. The RZR is a great machine, but it is limited on space to carry stuff. Like you said MWKE, you have 5 people in your family. You could buy the bench seat for the back and fit your whole clan in there.
    • By Winnem
      Hello fellow atv riders. I'm looking for people with experience with TGB atv.
    • By Bobbywolf
      I am working on a basket case for a friend.  It is a 98 Big Bear (YFM350FWB).  It came with a parts machine which is a 96, which I am coming to find out is VERY different from his machine.
      Anyway, first thing is first.  I checked compression, 150psi.  Valves are set correctly, and the engine is in time.  I cleaned the carb, and there was some junk in the passages.  It is a chinese carb, which I figured from the lack of markings or lettering altogether.
      The bike runs.  It idles ok, but breaks up badly under acceleration.  Pulling a new spark plug shows it is running lean.  White strap, with no black whatsoever.  So I have the carb adjusted with the mixture screw out way too much (about 5 turns), and the diaphragm needle lifted to the top slot.  It is still not getting enough fuel (or too much air).  It backfires through the carb, and cannot get above idle without carrying on.  The carb boot is in good shape, so it isn't pulling any air there.  I did test this as well by spraying ether around the boot when running, looking for intake leaks.
      Anything big I am missing here?  I am starting to believe that this chinese carb is the issue.  This quad came with the original carb, which I would like to rebuild and use, but the mixture screw is totally stuck, and stripped way down in its recess.
      Thanks for any assistance.
    • By p5200
      I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
    • By p5200
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
