Who Owns a
By p5200
I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
By p5200
By Powersrepair
I have a Suzuki lt185 and she is sounding like a cammed diesel after installing a new carb. Would running it like this be bad I can definitely adjust if needed but it if won’t cause damage why change it.
IMG_5131.MOV
By Quadman11
Hi Guys, First post.
I'm Having an issue with my KLF300 2X4.
Just purchased a 2000 model KLF300, when i first rode is i noticed the gear shifting from reverse to first and vice versa was extremely hard and stiff.
Now When the bike is running it is Shifting straight past neutral into reverse without using reverse lever, making neutral impossible to find. Also the neutral light and revese light has stopped working. To get the bike started i grounded the green wire coming from the switch so now i can start it again but the shifting issue is still there.
I have adjusted the reverse lever and cable so that it is fully retracting but this hasn't changed anything.
Can anyone recommend anything to check etc?
Thank you.
