pics of my girlfreinds blaster, custom pink paint/seatcover, tag aluminum bars, fast trecker 18x11x8 rear tires on itp aluminum rims. Motor is bores .40 over with a wiscoe stock compresion piston, Vito's 3, stroker stuffer crank, new bearings, oil injsection removed (including gear for it) tors removed motion pro throttle cable installed. Runs with stock head pipe/silencer rejetted stock carb, stock airbox, makes for a wicked trail machine! tons of tourqe! kind weird for a blaster, oh yea dont forget the wicked pink/white flamed shock covers!:o
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By quadnut20
      Looking at replacing tires on my 2003 Foreman and was seeing what everyone is recommending fore it ?? Its mostly a plow machine but in the summer the  kids take it out !!
    • By cruteg8
    • By sunn
      Any ideas?
