'97 Bayou 300 4x4 KLF-300C, but not really brand or model specific.  I'm having trouble re-installing the Big Coil Spring in the recoil (pull rope) starter. I'm hoping someone knows an easy tip or trick.
Thanks for all the help this forum has given me already!
Success! Gloves, safety glasses & patience are a must!
Small, straight jaw vice grips solved my problem. I clamped hook at the start and half way around, clamped it again. Cumbersome, but the spring stayed in position as I coiled it around. Each wrap, holding the spring down tight, remove, adjust & re-clamp the vice grips. After a few wraps, the 2nd vice grip was not needed, which made it easier. Eventually, the remaining coil is small enough that it doesn't fight back & can be put into place. Grease it all & reassembly from there is straightforward & easy.
Hopefully, this will help someone else.
    • By WeeBee
    • By Fonne
      Hi
    • By Elk
      2002 Polaris Magnum 325
    • By logray
      Hi all,
    • By HoldenBoy
      Hi all,
