Join Today, It's Simple and FREE!
By JacobSlabach
Got a 04 Sportsman 500 that wasnt running- owner said it needed a stater and a new battery. It ran rough (been sitting out in the weather for a while). A friend and I started by adding a new battery and it would start barely with the choke and his hand over the air-filter. I decided to install the new battery in the holder on the side. we had it on the rack because the old on was still in the bike. I tried to be nifty by turning the battery to put the terminals in an easier spot to get to, but forgot to reverse the cables too. In a sentence, I reversed the positive and negative on the battery like a dummy. When we discovered my mistake and corrected it, we turned on the bike, but the display did not light up and the key did not turn on the starter. jumping the solenoid worked the starter, so we thought the solenoid just burned up when I reversed the pos and neg... new solenoid and no difference. what have I burned up? Also, the shifter does not seem to do anything in the trans. it slides back and forth like its stripped in the trans. any help would be appreciated!!
I think the biggest issue right now is the electrical.
By Christian Brindle
I have a 2000 Polaris Sportsman 500. A year or so ago we got it running after replacing the kill switch. It ran great but after some use for a couple months it got a flat tire and for some reason we just forgot about it and it sat for some time. Before it sat i replaced the gas cap, fuel filter, fuel pump, petcock, battery, starter relay, oil and oil filter. I recently went to start it and it started so quickly and without choke or throttle but the ATV wouldn't move till about 1/4 throttle and it wasn't really a smooth ride until 1/2 throttle. it also would bog out randomly after you came to a stop and sounded like it was getting too much fuel. I cleaned the carb and adjusted the air/fuel screw to 1 3/4 turns out. I also messed with the idle and the throttle cable adjuster up on the handlebars. It's safe to say it now runs worse than when i started working on it 2 days ago. It takes more effort to get started and bogs out idling after about 30 seconds. I tried adjusting the idle but every time i do it'll get to a sweet spot but after driving it down the driveway and back the idle will go up and down to the point where i can't put it in gear because the gears will grind. Any thoughts or ideas would be greatly appreciated. Thanks
By joninak
I'm working on a 2018 Sportsman 570 and found in the service manual that there are two different torque methods for the head bolts depending on whether the bolts are silver or black. Well, silver bolts came out of my engine and I'm going to be replacing them with new bolts, however the parts fiche doesn't specify bolt color or that there is even an option!?!
Has anyone on here been through this before and can offer insight??
TIA
By flyinbrian365
View File 2019 Textron Wildcat Trail Service Manual
This Textron Off Road Service Manual contains service, maintenance, and troubleshooting information for the 2019 Wildcat Trail. The complete manual is designed to aid service personnel in service-oriented applications. This manual is divided into sections. Each section covers a specific vehicle component or system and, in addition to the standard service procedures, includes disassembling, inspecting, and assembling instructions. When using this manual as a guide, the technician should use discretion as to how much disassembly is needed to correct any given condition. This service manual is designed primarily for use by an CatMaster Basic Level technician. The procedures found in this manual are of varying difficulty, and certain service procedures in this manual require one or more special tools to be completed. The technician should use sound judgment when determining which procedures can be completed based on their skill level and access to appropriate special tools.
Submitter flyinbrian365 Submitted 02/18/2019 Category Textron Off Road UTV
By flyinbrian365
View File 2019 Textron Wildcat Sport Service Manual
2019 Textron Wildcat Sport Service Manual.
This Textron Off Road Service Manual contains service, maintenance, and troubleshooting information for the 2019 Wildcat Sport. The complete manual is designed to aid service personnel in service-oriented applications. This manual is divided into sections. Each section covers a specific vehicle component or system and, in addition to the standard service procedures, includes disassembling, inspecting, and assembling instructions. When using this manual as a guide, the technician should use discretion as to how much disassembly is needed to correct any given condition. This service manual is designed primarily for use by an CatMaster Basic Level technician. The procedures found in this manual are of varying difficulty, and certain service procedures in this manual require one or more special tools to be completed. The technician should use sound judgment when determining which procedures can be completed based on their skill level and access to appropriate special tools
Similar Tagged Content
By joninak
TIA
By flyinbrian365
View File 2005-06 Polaris Sportsman 400 450 500 Service Manual
2005-06 Polaris Sportsman 400 450 500 Service Manual.
Full ATV service manual
Submitter flyinbrian365 Submitted 02/18/2019 Category Polaris ATV
By joninak
Well, it overheated then started blowing white smoke!!
I have it torn down & the cylinder appears to be warped. Going to have the head checked out next but in the meanwhile... Does anyone have the torque sequence/specs for the head bolts??
TIA
By flyinbrian365
View File 2010 Polaris Sportsman 850 All Models Service Manual
Full Service Manual
Submitter flyinbrian365 Submitted 02/17/2019 Category Polaris ATV
