Litte intro , just signed up ,nice site hope to get to know some fellow riders, im in the upstate New York area,
just purchased two new machines for wife and i , Christmas presents, we take delivery next week , igot a new 19, Kodiak se 700
and i gotwife a new Kodiak 450se ,  having a plow added to mine , we live in the woods so plenty of places too ride
Hello Airborne, welcome to Quadcrazy! You will love this site.
Nice bikes you have coming.  Hope to see some pics soon!
We are from ny and ride in the Catskills area. All wooded type riding.
Goos luck with the bikes.
Safe riding!
    • By Fonne
      Hi
    • By tepin
    • By Johnnynv
      I recently bought a 2006 KFX  700 that had been sitting for 10+ years, started to replace the fuel system and the fuel pump has a connector that does not fit the same as original.  The plug has opposite slot as original.  There are two plugs on fuel pump bracket, some tiny sensor and fuel pump.  The new fuel pump plugs in the same place as tiny sensor, where as the old fuel pump plugged into opposite position.  I took old connector off bad fuel pump and repined it to new one, but now am questioning if this was the right thing to do.  I did pay attention to wire placement but just feel like there should be a direct replacement.  From the pictures on partzilla website, I cannot find a different option.  Has anyone run into this issue?
      Best ATV for Older Riders
      Polaris Sportsman 570 EPS
      Best Reliable ATV for Seniors
      Honda FourTrax Rancher EPS
      Best Features
      Best Premium Comfort ATV
      Can-Am Outlander MAX
      Standout Comfort Features
      Best ATV for Easy Handling
      Suzuki KingQuad 500AXi
      Why Older Riders Like It
      Yamaha Grizzly 700 EPS
      Best Features
      Arctic Cat Alterra 600 TRV
      Key Advantages
      Electric Power Steering (EPS)
      Automatic Transmission
      Lower Seat Height
      Two-Up Models
      Hand Warmers and Heated Grips
      Adjustable Suspension
      Buying Too Much Power
      Ignoring EPS
      Choosing Aggressive Tires
      For most mature riders:
      Final Thoughts
