Hey folks, just was given a 95 400l 2x4. After spending about 400$ to get it running and riding  I’m just wondering if there’s anything I need to know about this thing. The oil injection appears to be working, it starts up first crank but needs a little help to stay running the first couple minutes. It runs well and doesn’t appear to have any leaks anywhere, the oil injection appears to be working as well. Never owned a Polaris or a 2stroke bike before!
Wow cool find in such great shape.   The older bikes usually take a little longer to warm up. So I would not worry about that.  It’s normal.  Once she gets going she runs good like you said.   Try to keep it in tact and running good.  Sweet bike.
Thanks Frank, the previous owner did a bunch of performance modifications to it, an aftermarket reed, and carb, bigger rear sprocket, aftermarket exhaust, and shocks. Also included all of the original parts, I did also replace the belt and chain as well as put a stock size sprocket back on
Keep a very close eye on the counter balance gear case. It only holds about a half a cup of oil that is responsible for lubing not only the counter balance gears but also the water pump and oil injector. The gear case is on the Mag side of the engine.Newer models have a short dipstick on the rear portion of the engine. Older models have a oil level plug on the front. I think the manual recommends 10w-30 or 10w-40. Probably the most overlooked area on these engines that can end up causing the most damage. Were all used to EFI these days,just turn the key and its running from dead cold. Engines with carburetors take a few minutes to warm up.  Those are great engines though. Excellent power to weight ratio. Make sure the air box isn't cracked either.They were known for cracking and letting dirt bypass the air filter.
    • By HTOverland
      We have two 2021 850 XTP MAXX OUTLANDERS with nearly identical VINS. Both ATVS had the DPS error out the exact same week. Repair shop says need new DPS motors. How is that possible? Anyone else have DPS issues?
    • By quadnut20
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
