    • By Coyote251
    • By middlebrookgt
    • By 97kingquad
    • By maxbeg
      hey guys, I just bought a bayou 220 1989 and it doesn't start manual and electronic, keep blowing the fuse on the starter coil 20 amp when I plug the battery, ignition is not even on.
      I removed the body to make myself some space to see the wires, they are not that bad. The only thing that I found is the relay assembly is rusted on the top, like water infiltration in the relay.
      lets me know if you ever have experienced this problem or you have solutions for them.
