So I love my hids. The only thing I don't like is when you switch from low beam to high, the low beam turns off. We all know that hids take a few seconds to power up. Thus causing blindness for a few seconds.
How do I wire it so when I turn on the key to the 3rd position the low stays on all the time
Simple solution is go to the ignition wires with a test light and find the wire that goes live (12v) when in third position and tap that with a wire connector and extend to your hid wire (fuse in between) right where you tap it. This way they are always on with the key. You have to disconnect the existing wire  that’s feeding the hid now though.
Yea it’s pretty simple. The low beam light should have a small plug on it right behind the light assembly.   Pull that off and leave it be.  Just need a few feet of 14 gauge stranded wire red preferably and one inline fuse and a crimper.  And they sell connectors that will plug right back into the light fixture plug for your new wire.  Your wire should have the new plug connector on one side and the inline fuse and a tap connector at the area of the ignition.
    • By Adamb2025
    • By T37Mark
    • By Louznmemind
      I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
