Wet and Sticky Snow ... 05 Mar 2019
By mikeexplorer
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
This is from my side drive to the top of the property.
The Dog loves the runs.
No snowflakes were injured in the production of this video.
https://youtu.be/tKjBFuHCkM0
By Spartacus Stroppel
So I have a 2001 Kawasaki prairie 300 I could not find tough country snow plow... it's a older plow too boot... so I made the plow mount and updated the plow with some skids.
Mount plate is 1/4 steel plate and so are the pin points
The skids are off a moose plow. I got some plumbing black pipe for holders to weld to the blade and braced it with pieces left over from the plow mount 1/4 steel...
1/4 plate cost $45
Skids cost $24
U bolts and other hardware where $20
I got the blade free
