Here's a kind of long video from my last ride ... so get some popcorn, a drink, a comfy chair & sit down & enjoy the show ... and no commercials !!!
PRAY FOR SNOW !!!!
    • By mikeexplorer
    • By DayBreakJim
      20230725_171507.mp4
    • By Ulfthednar
      The Dog loves the runs.
      https://youtu.be/tKjBFuHCkM0
    • By Spartacus Stroppel
      So I have a 2001 Kawasaki prairie 300 I could not find tough country snow plow... it's a older plow too boot... so I made the plow mount and updated the plow with some skids.
      Mount plate is 1/4 steel plate and so are the pin points
      The skids are off a moose plow. I got some plumbing black pipe for holders to weld to the blade and braced it with pieces left over from the plow mount 1/4 steel...
      1/4 plate cost $45
      Skids cost $24
      U bolts and other hardware where $20
      I got the blade free
    • By Rich1028
      Video from last Saturday on the Denton Trails...PONDS!
