Changed fuel pump, has spark and good compression. Tried a gravity feed trick and still couldnt get it to fire off. But it does try to crank when i spray starter fluid. With pump connected and fuel hose off, it should still pump fuel, correct ? But its not. And i cant find anything online about this bike. Has less than 200 hrs, so barely gets ridden (wifes). New fuel in tank. Any suggestions would help. Thanx....
Was the bike sitting where the fuel in the  carb has gone bad and causing a problem? It sounds like there is a fuel restriction someplace. Fuel dries up and gets very thick like a varnish and flakes up inside the bowl.   Bad gas ? Some dirt in the carb?  Also keep in like that the sometimes the fuel pump needs to be primed.  Could be air bound.
Thanx for input guys. As soon as i hit submit to this question, i realized that i didnt replace the burnt fuse when the pump first f’ed up. So low and behold, it starts now and pumps great. But i did pull carb out and inspect it earlier in job. I feel like a total dip s#@$. But its working, so dont feel to bad now. Thanx for ya’lls help
  • 6 months later...
it would be nice ro flush your tank,fuel hoses and install a new filter to prevent this from happening again  .Enjoy your rig!!
Edited by fbiondip
better grammar
    • By 88bigbear
    • By cfherrman
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By logray
      Hi all,
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
