By mga
My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
By Dan Kroes
Does anyone know what size wrench I need for the middle axle jam nut on a 2001 Polaris Sportsman 500 6x6? same part used on rear axles of these models.
2000 INT'L BIG BOSS
2001-2002 INT'L BIG BOSS 6X6
2002 LUH 6X6 P
SERIES 10 PTV 6X6
1998 SCRAMBER 500
1998-1999 SCRAMBLER 400
2001 SCRAMBLER 400 2X4
1999 SCRAMBLER 500
2001-2002 SCRAMBLER 500 2X4
2001-2002 SCRAMBLER 500 4X4
2002 SCRAMBLER 500 4X4 FREEDOM
1999 SPORT 400
2000-2008 SPORTSMAN 6X6
2005-2007 SPORTSMAN 6X6 MV
2000-2002 TRAIL BLAZER
1999 TRAIL BLAZER 250
2002 TRAIL BLAZER FREEDOM
2000-2002 TRAIL BOSS
2001 TRAIL BOSS 325 SE
2000-2001 XPLORER
2001 XPLORER 400
2002 XPLORER 4X4
By mywifeknowseverythin
:yes:In everyone's so Humble opinion.....If you had the Cash.....and you were in the market for Either an 08 or 09 Utility Quad......Which Manufacturer would you Flip your Mattress for????
Post your Reasonings.......And Which Quad you would buy...
At the end of this Poll.....We will take the best two......Then Poll them..... Which would make this a True.....This Vs. That.....
By cervenakrava
Hi,
New to ATV repair but willing to learn and get my hands dirty.
We start the atv and even with a good battery, it will drain it very quickly and eventually the atv shuts down. Checking the battery afterwards shows significant drain on it.
Would this be a shot alternator? Some electronics module?
Thank you kindly. Just need to be pointed in the right direction and then with a repair manual will get to it.
Cheers
