    • By cervenakrava
      Hi,
      New to ATV repair but willing to learn and get my hands dirty.
      We start the atv and even with a good battery, it will drain it very quickly and eventually the atv shuts down. Checking the battery afterwards shows significant drain on it.
      Would this be a shot alternator? Some electronics module?
      Thank you kindly.  Just need to be pointed in the right direction and then with a repair manual will get to it.
      Cheers
    • By Shook
      Hi I have a 2000 big bear 400 and i just put a new carburetor on it and it idles fine but when you try to accelerate it sounds like it is going to die, so when it sounds like it is going to die I will give it more throttle then it will go just fine.
      With yesterday's website updates, we've added the ability to use Giphy GIFs. You'll see the button in in the editor ribbon
      We are keeping the images at a PG13 level 😋
      Enjoy, and please report any issues!
    • By Rick Shropshire
      Im new on the site and making my introduction with this. Im Rick and I just bought a 91 bayou 220a for $125. Its been treated rough but is still complete and functional with the exception of not being able to run long before it locks up. I Have to manually turn back the crank to get it to fire again. I didnt hear any knocking or anything, it sounded good til it locked again. Im getting ready to pull and crack the case open and have a peek.
    • By izoneterror
      Hi
      Im having an issue with my kawasaki bayou klf 220cc
      The problem i am coming across is that the quad will start for about 30 seconds then stop but after it has stopped the engine seizes up until i get a socket on to lossen it up again, It keeps doing this over and over again.
      Any advice would be appreciated.
      Sorry if i have done this wrong im new here
