wayyyy to loose.  It should have about a inch or so wiggle room- you're looking at like 3 or 4 inches lol  There should either be a tensioner or the rear axle adjusts- lift the rear end and there are some bolts to loosen and then the axle swings forward and backward- you want to pull it fairly tight as the chain loosens up with heat.  Also make sure the chain is well oiled so none of the links are bound up- that will make it jump sprocket too even if its tight.
that chain is so loose, it might have one too many links on it- I would try tightening it first tho
I had the same problem with a Chinese 110.  Seemed to be a wight issue.  When I rode the chain jumped off.   When the kids road (<100#) it was just fine.   Never could get it to stay on under load.
  • 7 months later...
    • By Yamahahahaha
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
