wayyyy to loose.  It should have about a inch or so wiggle room- you're looking at like 3 or 4 inches lol  There should either be a tensioner or the rear axle adjusts- lift the rear end and there are some bolts to loosen and then the axle swings forward and backward- you want to pull it fairly tight as the chain loosens up with heat.  Also make sure the chain is well oiled so none of the links are bound up- that will make it jump sprocket too even if its tight.
that chain is so loose, it might have one too many links on it- I would try tightening it first tho
I had the same problem with a Chinese 110.  Seemed to be a wight issue.  When I rode the chain jumped off.   When the kids road (<100#) it was just fine.   Never could get it to stay on under load.
  • 7 months later...
    • By Yamahahahaha
    • By shorty
