1995 Bayou 220 Reverse lever seal leak
By buriedpast
By hengstserepair
Nuetral: Runs as expected
Lorne
By rjsummer
By Eisenmatt17803
Good Morning!
Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
Thanks in advance.
By marlon smith
