1988 Yamaha 350 Big bear No spark
cfherrman
Edited by cfherrman
  • Ajmboy changed the title to 1988 Yamaha 350 Big bear No spark
The 3 white wires? No
Haven't checked the regulator, how do you check that, I could search that if it's easy to find.
I haven't checked the kill switch wire. Will tonight.
I think I checked the fuse in the front of the atv, will double check.
I check the coil resistance, I have also been using a Ford coil on plug as well to rule out a bad coil as the new coil thumps a lot when you manually spark it.
Thanks!
The old pickup coil, 180
old source coil, open
New pickup coil, 400!
New source coil, 280
Last night I pulled a prong from the old harness and wired it into the new pickup coil. The new on had them soldered together so I split it and made it 4 wires. It had no spark before and after.
I'm gonna check the kill wire, I did check the kill switch awhile ago.
I’ve always had luck with Caltric. I know a few ppl have said they weren’t happy. To date on starors only I’ve been happy. They always matched up and held up.   That’s the only aftermarket part that i would purchase. I only buy oem otherwise for all other parts.  They make it well but then again it's only a stator coil. It’s not rocket science building stators.
Stator came today and I tossed it in real quick, no spark. Note I just have the cover on no bolts and only a little oil, I just turn it over a few times, does it need to crank a bit before spark?
I don't have any time tonight so I'll have to mess with it tomorrow. I'll have to recheck everything and all wires.
Does the voltage regulator affect spark?
Does the source coil color wires matter
Do the pickups matter, there's two can they need to be switched?
No I got a sinus infection right when I got the new stator, I tossed it in but no spark. I was down for two weeks from being sick and didn't recover my time. My brother saw the 4 wheeler and bought it for $350.
He checked everything out and thinks the cdi is bad as well. He doesn't like the new stator is twice the resistance of the original one. He's gonna double check everything and if cdi is bad probably going with Arduino ignition.
I will keep you updated.
    • By oxidized_black
    • By Otter9099
