Sportsman 500 (96) AWD on/off
By HoldenBoy
Hi all,
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
what can it be or what can i do to fix this?
thanx in advance
p.s. Sorry for my bad english it's not my first language.
By Rockbottom
any ideas how to correct
thanks ahead
By digrig
Hey everyone,
By middlebrookgt
