Something I've noticed with the AWD on/off operation. When AWD switch is in the on position and the AWD light is on (trans engaged), turning the AWD switch off kills the engine. With trans in neutral, AWD light is off, turning switch off does not kill engine. Since I don't have the operators manual yet, I'm wondering if this is normal operation?
Thanks, Ray
    • By OldATVowner
    • By HoldenBoy
    • By wilmpie
      hi everybody
      thanx in advance
      any ideas how to correct
    • By digrig
      Hey everyone,
