My Grizzly started dying in the middle of riding it.  Most of the time it was as I was decelerating or idling.  It did this for a while and I thought it was just bad fuel.  I had siphoned out most of the tank and put fresh fuel in it thinking this would fix it.  However, after riding it some with the fresh fuel it was still doing it.  Last night it died and I couldn't get it restarted.  The battery is 8 years old so I thought maybe this was not keeping enough charge so I put a brand new battery on it.  Still nothing.  I pulled the spark plug to find I had zero spark.  Does anyone have the service manual that walks you through all the steps you are to take when you aren't getting spark?  I was just going to go back to the coil next and keep tracing my way back.  I'm not sure what resistance should be at the coil nor exactly how to test it.  Also not sure how to test the plug to make sure that is good.
Any help you guys could lend would be greatly appreciated.
Of all the things, it turned out to be a faulty spark plug.  I have been riding ATV's and dirt bikes for 30 years and in all that time I have never had a spark plug go bad.  This Grizzly had 60 hours on it when the plug went bag - I have to assume it was just a quality defect in the manufacturing of the plug.  Very random in my opinion.
You know for the first time I had the same thing happen this past weekend.   EFI Rancher 420 started doing the same thing.
In thought for sure it was a fuel delivery problem.  Pulled the plug after I barley got the bike back to my truck.  Turns out no spark.  I took a shot and popped a new plug in and bang! Like new the bike ran great.  Strange but simple fix thankfully.
    • By quadnut20
    • By buriedpast
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By HoldenBoy
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
