OEM vs Aftermarket on a 95 kingquad 300
By mga
By bob2007
By Gwbarm
I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
By cavry
Thanks for any help
Cavry
By hardcastle
