Similar Tagged Content
By Massey Josh
I have recently purchased at 2006 Polaris Phoenix and I need to replace the CDI box. Does anyone know if the CDI box off a 2005 model will fit the 2006? Thanks
By Jack.hart
Need help with a 2007 polaris phoenix 200 no spark new cdi,new ignition coil,checked resistance on pulse coil and stator,not getting power to start button now guessing the solenoide went in all the testing not sure.also have three ground wires to battery is this normal or..?
By Michael Beck
Has anyone tried the aftermarket carbs for a Polaris Sawtooth/Phoenix? I am trying to decide on a rebuild kit or new carb.
By colin james
View File 2006 Polaris Sawtooth 200 & Phoenix 200 Service Manual
This is the service manual for 2006 Polaris Sawtooth 200 & Phoenix 200 ATVs. Download all the chapters for the complete manual.
Submitter colin james Submitted 11/25/2018 Category Polaris ATV
By colin james
Similar Topics
By Sha35297
So, I got this 07' Polaris Outlaw 90 in the shop to rebuild top end and transmission. Replaced all bearings and gears in the transmission. Replaced cylinder and piston with brand new parts. Put the engine back on the frame and fired it up. Started great, but had a taping sound in the lower crank case. pulled the flywheel cover off and found the flywheel was wobbling and hitting the stator. I then replaced the stator and flywheel with brand new parts. Timing is all set on the timing marks now, but when I turn it over it kicks back when it fires and ends up stripping the starter idler gear. I've replaced the starter gear once already and now have to replace it again. Is it possible that the timing marks on the flywheel are off or maybe this flywheel is not for this exact model? Thinking of advancing the timing to try it, but don't want to keep going through idler gears.
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By ATVNetwork
news A powerful trail machine ready to tackle the hardest adventures.
Polaris unveiled the 2021 Sportsman 850 Trail Edition ATV with factory-equipped enhancements to tackle the roughest terrain. View the full article
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By jung4g
The quad has done this off and on, almost since new, but it's gotten worse this year. Sometimes if I freshly charge the battery, it'll work fine, others times that won't matter. Turning the key to on it sounds like it's connecting as I go to the start position, slightly before the full turn, but it's not like there is just a sweet spot to find, it's totally erratic.
Now the battery is basically dead so I put a new, slightly bigger AGM battery in today to replace the factory one with all of 800 miles on it, but those have lots of plowing hours included.
I was able to get it started once, but it still went into limp mode after just a few moments of driving it (that's another topic), so I put it back in the garage and started probing around. Now it doesn't even try to turn over.
Is an ignition switch, the $18 shipped aftermarket variety on Amazon worth a shot? Or should I go straight for the starter? The new switch may not come for over a week, so I hate to just put my hopes in that if I'm missing something obvious. Fuses are good, so it's not something super obvious.
